There is no accurate way to really judge your speed based off of the tach(even if it did read 100% correctly). There are too many factors.
Wind, temperature, humidity, rider height and weight, rider tuck/aerodynamics, mirrors on or off/aerodynamics, road surface flat, up, or downhill...no matter how slight, ect. ect.
What the bike is capable off vs. what the rider and conditions allow are very different.
A stock gen2 under perfect conditions is capable of doing 186mph with at least one mile of road to get there. With the restrictions off and stock gearing(again with perfect conditions)mid 190's are possibble.
Just an fyi too, 200mph is not possible with stock gearing.
Gps should get you within a couple mph of what you are really doing.![]()
I think the tach method can be very close. Of course a GPS is best. By tach, unless you have changed gearing or tire size you should be close. If not, there is something mechanically wrong like the clutch slipping. You are talking about a mechanical system of gears ultimately ending up with a tire against the road. "Wind, temperature, humidity, rider height and weight, rider tuck/aerodynamics, mirrors on or off/aerodynamics, road surface flat, up, or downhill...no matter how slight, ect. ect." Will affect power to that gear or how much power is required to go faster and reach maximum speed but the tach should not lie, it will just be lower.
The engine can continue to rev higher because it is working harder.
However, if any of the conditions above are present to limit it in any way you will not achieve the same speed.
Same principle as driving a truck at 60mph in high gear and it's taching say 2k rpm.
Now pull a 1500lb trailer at 60mph with same truck in same gear, you will tach more to accomplish same speed.
Just like a 300lb rider vs a 150lb rider in 6th gear trying to go as fast as possible.
Not really seeing your logic with this one...
RPM is based off the crank speed, The crank spins the clutch basket in which goes through the transmission to the rear wheel. UNLESS you have clutch slippage its all the same. I can see if the clutch was wore out and slipping then yes the RPM will be higher. Prove this point by going 60MPH and look at your tach, now find a steep upgrade incline and do the same at 60 MPH I am betting that your RPM is the same.
In theory the Gen II exceeds 192 M.P.H. at 10.5K R.P.M. s according to gearingcommander.com
To OP, get a GPS, it will capture max speed.
you keep bringing them up but if i remember correctly gearingcommander.com uses speeds based off of runs on a dyno which has no wind elevation changes etc
I'm not a fan of gearing commander for several reasons.
A derestricted stock gen2 under perfect conditions is also capable of a little more than 192mph.
The speed limiter on the gen1 kicks in at 10,200 in sixth gear.......thats about 10,400-500 on the tach. I'm pretty sure gen2's are the same....same 186mph limiter in 6th. If your tach went to 11k in sixth your speed limiter is either bypassed or not working...which is a good thinghad my 2011 busa at 11,000 rpm in 6th gear today wondering if i was at 180 mph or above?
That makes zero sense unless you are saying the clutch would be slipping for the heavier rider ,and even then, it's not making sense.I'm also betting that the 150lb guy's rpms at 60mph are less than the 300lb guy up a steep incline in the same gear and speed.
mikbusa said:That makes zero sense unless you are saying the clutch would be slipping for the heavier rider ,and even then, it's not making sense.
