I will admit, this issue is partly my fault for the mis-shift, but the problems doesn't happen in other bikes I had in the past. I'm hoping it's not a tranny issue.
1st off- On the Busa, the shift throw between 1st and 2nd seems longer then other sport bikes I've had in the past. is this normal?
What happens is, sometimes, while going from 1st to 2nd, and if I'm riding it hard and over 8K RPM (estimate), it won't shift out of neutral, unless I slow WAAAAAY down, to like 30-40mph, and low RPM. I'm not speed shifting, clutch shifting only.
I'm not sure either I'm not engaging the foot shifter enough to get passed neutral or it's just falling back into neutral.
Anyone have any experience with this?
