jay21112
Ok, today I did some more work today and I think I completed the air box.
I did the small airbox mod by drilling holes all around the flapper then using a serated knife to cut out the flapper. Then I sanded it smooth (or as smooth as I could get it) with a file, a drill, and some sand paper.
Then I removed the intake air control valve actuator from the floor of the air box (and tossed it) and sealed the hole with some high heat silicone and the flapper which I cut into a circle with some shears.
I plugged the line leading from the intake air control valve actuator to the vacuum control solenoid valve with a left over valve stem cap from my car (and some more silicone).
Also plugged the pair valve hole with a cap from brock's pair removal kit (and some more silicone...getting the drill yet?).
Then....I installed the BMC race air filter and put everything back on the bike.
Now I have 2 questions....one major and one minor.
Look in the pics below...look at the one of the bottom of the airbox. There is a hole for a hose in the top of the airbox which I cannot remember removing a hose from. When I put the airbox back on the bike I couldn't find a hose to hook up to it. Is there a hose that hooks up to it? If not, should I cap it off and seal it?
The other question regards the BMC air filter. Look at the pic with the stock air filter. There is a piece of foam at the bottom of the pic. This came in the box with the BMC air filter but I have no idea WTF they want me to do with it. Any ideas? I thought maybe they wanted me to tape it to the bottom (inside) of the air filter...but I thought why?
So any help (especially in answering the first question) would be appreciated)
Here are the pics:
Here are the pics:
