Website: SportbikeWrench.com - Motorcycle Performance Parts, Professional Advice, and HowTo Videos
Discount code (15%): tufbusa
I purchased these videos by Dave Moss and found them to be full of great info on how suspension works, how to read tires, what each knob does and how the adjustment affects how your bike behaves.
Dave Moss is a very well respected suspension tuner who travels this country some 260 days per year tuning around 3,500 bikes annually. I have attended Dave's seminars and the man has a magical touch when it comes to suspension.
If you are truely interested in learning how your suspension works, how to set your sag, compression damping, rebound damping, read tires and learn how your suspension affects them, this may be the best forty bucks you'll spend this year.
Did you know that a tight chain can increase tire wear up to 40%?
Do you know how to tell if your front tire is plowing during corner entry?
Dave explains these things.
Dave also has cameras set up on both front and rear suspension showing how the suspension reacts to different suspension settings during hot laps around the track (Priceless)
My favorite section is on "How to read tires"!
No matter how well schooled you are on suspension, you cannot watch these dvd's without learning something!
If you decide to make the plunge feel free to use my discount code.
