I am slowly figuring out how to use the autotune feature with the PCV. I loaded my old map back in which helped out tremendously...and added the AFR table per dynojets map suggestions.
I can now see the AFR numbers moving in the single column on the right under the RPMs but I have not been able to see any changes recorded on the trim table yet.
As far as I can tell, I should be able to tell what the trim numbers are to make the proper adjustments~?~
