2008 weight reduced 50 kg.
Latest reviews
Pros: All
Cons: nothing
Fantastic build. You can gain approxx 2 kg, if you change the wheels to GSX-R1000 wheels, more, if you change to forged alu or carbon wheels
  • Like
Reactions: BusBus
Berlin Germany
Berlin Germany
yeah !
the less weight the later you have to engage the brakes. ;) :banana:
did you (for racetrack) already
put off
the generator / rotor ~ 2.5 kg
balancer wheel/shaft ~ 1.0 kg
and
changed from acid battery to lifepo4 ~ 1.5 kg
and
reduced the crankshaft´s weight ~ 2.5-3.0 kg
feket663
BusBus
BusBus
Lots of good ideas Berlin, and I see there is a lot more to come for in the engine, but mine is a work in progress and I first wanted to see how far I could come with the chassis.
I did however change the original 4200 grams battery to a 740 grams Aliant battery.
Item information
Added by
BusBus
Views
1,910
Reviews
Last update
Rating
5.00 star(s) 1 ratings
More in Gen 2 2008 - 2020
Share this item
