00 Injector Harness vs 05 Injector Harness Question
wizardstrex
My Question is
2000 harness on Bottom
2005 harness on top
on my 2000 Injector Harness the Four Signal Wires are on the right side of each connector and ground on left
on the 05 harness the Color code wires match for each injector per Service manual and signal wires go the same
connection at the main wiring harness on both injector harnesses, it's just that the signal wire is on the 05 injector harness the signal is on the left and Ground on the
right.
does it matter as to which side to the injector plug the signal wire goes in as long as they are all on the same side and the signal wires go
where they are suppose to on the main Harness
see pic
thanks in Advance
