01 busa headlight problem
Busagang12
Headlights won't come on but all the other lights work checked fuse light switch connectors everything is good help me please
If you press the passing switch on the left switchblock, in front of the hi/lo switch, does the headlamp work at all?
Does your model have a 'on off switch' on the right side switchblock?
Do you have a wiring diagram?
What's the year model of the bike?
So when I crank my bike the headlight doesn't come on I push the high low beam switch it doesn't come on the left side blinker doesn't work but the right side does its an 01 busa 1300 the bulbs are good its a different headlamp
