02 busa. Front brake lever wont light up my tail light. Help
Underoath1122
I have an 02 Hayabusa and when I pull in my front brake, it does not light up my tail light. But.... when I press my rear brake pedal it light it up. Could it be the sensor on the front lever went out? Any help would be much appreciated.
Did you check and make sure both connections are on the front brake sensor?
I had the same problem with the rear brake pedal on my 07. Changed the brake light switch and it works fine now.
