Pretty good read there P12. And yes, the ram air effect you state comparing the Busa and ZX12 is right on-point.Oh to add to the ram air question....
the Busa's ram air is rather inefficient.... Suzuki placed the ducts in a bad place.
The highest point of pressure is right infront of the nose of the bike before the bike splits the air. The busa's air ducts are not only towards the sides... but also integrated in a way so that the air flows over the duct instead of inside it.
Those amazing aerodynamics hurt the ram air's ability to catch air .... the placement of the ducts and it's size is just poor engineering.
I'm not trying to wave the Kawi flag here... but kawasaki pioneered the use of ram air on bikes... they are proven to have the most efficient and power ram air systems of all the bikes.
Look at where they place their ram air ducts.... centered and forward.. usually in the form of a scoop under the nose of the bike or as with recent models... smack in the center of the front cowl (zx6r and zx10r).
Though not as aerodynamic ... the power from the ram air's added efficiency makes up for it plus some. bad thing is when going Turbo.... there is no use for the ram air and the exposed air ducts only slow the bike down.
Another reason why the Busa is just such a great turbo platform.
As for the power gained... the Busa will gain roughly 5-6rwhp ... but sadly it doesn't start to pressurise the airbox till around 140mph... so the ram air doesn't even show itself till around 160mph.
Other bikes like the Ninja's start making power at speeds as low as 85mph thanks to their efficient ram air systems.
At full blast the Ninja's (mainly the ZX9R and 12R) are making roughly 0.7 psi (boost) with the ram air.
Each 1 psi is worth roughly 14rwhp from what I'm told.
The ram air ducts are in fact nicely placed for turbo mods.Though not as aerodynamic ... the power from the ram air's added efficiency makes up for it plus some. bad thing is when going Turbo.... there is no use for the ram air and the exposed air ducts only slow the bike down.
...Good analysis there mate!Oh to add to the ram air question....
Well, think about it this way...The ram air ducts are in fact nicely placed for turbo mods.Though not as aerodynamic ... the power from the ram air's added efficiency makes up for it plus some. bad thing is when going Turbo.... there is no use for the ram air and the exposed air ducts only slow the bike down.
Although one of them is redundant when the intake runner is plumbed through it, the other is perfect for flowing nice cold air over the intercooler core resulting in excellent temp drops and more hp gain than any minor aerodynamics could achieve.
Depending on your intercooler is fitted.
