04 600mile Busa staling
Liquidous
my busa keeps staling. some times at a stop, when i rev the engine, as the rev comes down it stalls,
ive also been driving and it stalled on me 3 times already
anything i can check to see whats going on?
this is dangerous.
What is the idle set at? It should be around 1150 rpm and if it is below that it will sometimes die when you come to a stop.
It's the idle adjustment screw. Get some locktite. Lift your tank. Look for the throttle linkage (twist the throttle, and you'll see it move) and locate the adjustment screw (it's the one facing the back of the bike). put a few drops of locktite on the threads inside the spring. Tighten the screw until the bike idles at 1100-1200 rpms (1150 work well). Bolt the tank back down.
You're done!
Happy riding!
