pimpinphil
i had first noticed this about a month ago,when i was "yielding" through a stop sign,and right when i would start back on the throttle,it sounds like a broken tooth on the sprocket or something to that nature,and that was the only time i would hear it,everything seems to be running and working as it should.
and then tonight i was pulling up to the gas station,and the with the bike in netural,no clutch,a quick hit of the throttle,you can hear the same thing,however if i pull the clutch lever in,and do the same rev. no noise at all. the clutch seems to work just fine.
anyone have any ideas??? its been a little while since my last oil change,and the last one i did i used full synthetic suzuki brand.it has about 3000 miles on it. thanks for any help
