05 fairing donnot fit on 1999
samizx7
hey guys i was installing an 05 fairing. the upper did not fit on the right side fairing. are they different? what other years would fit an 05 upper. thanks
They should be the same. The only difference from the 99-05 is the lower fairing has an extra support on the early bikes. Three bolts on the lower by the tire and two on the 99's.
Upper should work unless something is bent.
I read a while back were Johny Cheese mentioned something about it not fitting.... maybe try a search or IM him......
