06' Busa Fuel Pump Removal
waldrop1994
Can someone instruct or direct me where i can find info on how to remove the fuel pump on my 06' Busa. Thanks.
remove seat...drain tank....remove tank (makes it easier)....unbolt fuel pump and manuever out.
The connector on the fuel line just clip on and only a small amount of fuel will come out when disconnected (sometimes?). UNplug the fuel pump.
To remove the tank disconnect the tip over sensor on the back right side of the tank (black unit) and take out the 2 bolts that hold the tank mount to the frame.
