(dadofthree @ May 27 2007,20:19)
(Turbo-Torch @ May 27 2007,20:43) New busas don't overheat and neither do old ones unless there is something wrong.
The dealer never burped the air out of the system. The process is nothing more than taking off the radiator cap and slowly rocking the bike back and forth until all air is purged. This has to be done everytime the coolant is changed and you wouldn't believe the amount of air that comes out. After the air is out top the radiator off again up to the neck and repeat the rocking to make sure there is no more air.
I hope you didn't overheat it, otherwise welcome to future head warpage/gasket problems. Don't bother burping it yourself, let the dealer do it. If it was mine I'd tell them to pick it up on a trailer and fix it. Also make sure you get a written and signed paper stating what the problem was so that next year if the head gasket decides to go you'll have something to fall back on.
Not to argue cause I sure as hell don't know what I'm talking about, but why do we have fan mod and engine ice threads all over the place; because Busa's don't like heavy traffic and niether do similar bikes.
I had to pull over a number of times in Mrytle Beach the past two weekends because of sitting in traffic. No spewing.
Hope that the radiator needs burping or the new kid at the shop overfilled the radiator.
It's under warranty, make em fix it.
