Ok here we go:
Busa Stats
Year: 2007, bought new from dealer 04/2008
Mileage: approx. 5000
Completely Stock bike
Story: I took a weekend trip from NYC to Delaware back in April of this year. On the return home, I was at the Holland Tunnel and traffic was moving slowly. I get through the tolls...look down...and go "WTF!!!" my bike is overheating. The warning light was on. I'm sure it had not overheated during the ride...it was like 45 degrees out as well. Since then it has been in and out of a local shop and they have yet to solve the problem. They replaced the following with new parts courtesy of Suzuki: rad, rad cap, thermo, & fan relay and the not even a dent in the problem has been made.
Observations:
Upon Starting Cold:
If stuck in traffic at this point and not able to move the bike must be shut down otherwise it will travel into the red and the warning light will come on.
I have been taking the bike to a Suzuki dealer in my area and they cannot seem to figure the problem out. The first time I took it there they pretty much thought that I was crazy I think because everything works fine initially. They just flushed the old coolant, inspected and ranw who knows what diagnostics. The symptoms returned. Second time I demonstrated the problem so that they actually realized that there was one in the first place. They kept the bike and returned with the conclusion that the radiator had a slight bend in the neck and was not holding pressure??? In two more trips back to them, they have now replaced the rad, rad cap, thermo, fan relay, checked the fan motor, and waterpump...both fine. They've said that the bike has been done every time and I have had to bring it back and forth. Every time I get on it I begin to overheat after awhile of riding in city traffic conditions. If you stay moving a good clip your fine. Please help! Let me know if you need anymore info but I tried to cover everything.
Busa Stats
Observations:
- The bike is not smoking and the oil is not milky or discolored.
- The bike cools down at 40mph and cools quicker at higher speeds.
- It will maintain temp well below the halfway marker on the temp gauge where the fan is not needed at 65+mph.
Upon Starting Cold:
- Coolant approx at lower mark on resevoir bottle
- Fan cycles on and off cooling the bike approx 5 times in traffic conditions.
- 6th cycle, fan will not kick on until slightly above halfway mark on temp gauge (should kick on right underneath halfway)
7th cycle will began higher temp than 6th cycle on and the fan will not cool as effectively
- 8th cycle temp higher and fan less effecive...at this point the fan will be turning on about 3/4 on temp gauge with less cooling power. Bubbles can be noticed rising through the resevoir from the lower bottle hose and the bottle will be well over the FULL marker.
