08 caliper spacer removal
Sincere876
How do I go about removing the spacers so I can mount the brembo calipers?
last time i serviced the brakes i removed them with the factory bolt. put it in without threading it and wigged it a little and they came out. they arent pressed it so it should take to much force. are yours seized on?
I haven’t tried it with the bolt but I will right now. Thanks so much
I wrapped the part sticking out in tape and used pliers to pull them out
Ive tried that and I still can’t get them out lol. I’ll try again with some vice grips. That should do the job
Got the brakes all squared away. Had my brother do a quick test run. One question the clicking noise at the end when he stops, is that a normal sound? Not to many Busa’s around for me to listen to.
