Droped my bike off fri it Velocity and Barry worked up a wicked package for me: STAGE 2 TURBO SYSTEM
SHIFT LIGHT
DUAL BALL BEARING TURBO
WATER INJECTION
LOW PROFILE BILLET OIL PAN WITH SWING PICK UP
0-6 SWING ARM
LOWERING LINKS
TOP TRIPPLE CLAMP
BOOST CONTROLLER VRBC
BOV
ADJUSTIBLE CAM SPROCKETS
PISTONS
RODS
GASKETS
SPACER PLATE
STUDS AND NUTS
QUICK ACCESS CLUTCH COVER
UNDER CUT TRANS
VALVE SPRINGS
BILLET CLUTCH BASKET
CLUTCH HUB
LOCK UP CLUTCH
STEEL VALVES
AUTO METER ELECTRIC BOOST GUAGE
CUT FORKS 1 1/2 TRAVEL
COST: ENOUGH
I'll try to post some #'s and pics when finished.
ps. does anyone have some $ i can borrow?
SHIFT LIGHT
WATER INJECTION
0-6 SWING ARM
LOWERING LINKS
TOP TRIPPLE CLAMP
BOV
PISTONS
RODS
GASKETS
SPACER PLATE
STUDS AND NUTS
UNDER CUT TRANS
VALVE SPRINGS
CLUTCH HUB
LOCK UP CLUTCH
STEEL VALVES
COST: ENOUGH
