10 simple rules for the group ride
BusaWhipped
Ground rules for the Group Ride. I posted it in the MNG thread,, then thought it deserved a thread of its own.
Hopefully we will have a lot of bikes on the Group Ride Saturday. Most of us have not ridden together before. Most of the group have never ridden these roads before. And some may have never ridden twisty roads before. Each of these add to the risk of the ride. We all want to have a fun ride, and we all want to arrive back safely with our bikes in one piece. With all that in mind, here are 10 simple rules for the group ride.
1) No stunting.
2) The leader sets the maximum pace of the ride. Ride your ride, go your own pace. Don't worry about not keeping up with the group. Folks will wait at stop signs and turns. We will regroup at regular intervals. If someone in-front of you is slower, pass safely (unless it's the leader). Enjoy the ride on these amazing roads, it isn't a race to lunch.
3) Keep a safe following distance. Don't ride up on the person in front of you too close. On the highway sections of the route, we ride 2 line staggered formation, leave 2 seconds between you and the bike in-front of you. In the twisties, we ride single line formation, leave 2 seconds between you and the bike in-front of you.
4) Always use blinkers and hand signals. Face it, some of our undertails, flush mounts, and other signals aren't that bright. A quick hand signal can quickly and easily tell the person what you are doing.
5) If you have time, and can do it without putting yourself at risk, signal debris in the road with your feet.
6) At EVERY stop sign, or any time turning off one road onto another, every rider waits until he/she can see the bike behind him/her. Do not leave the intersection without knowing the next bike can see where you turned by signaling the turn. This makes sure nobody misses a turn without the entire group having to stop frequently. We will regroup everyone about every hour.
7) When you have time (not in corners) make sure the person behind you, is still there. Face it, any minute we can eliminate noticing somebody has wrecked, could save their life. Similarly, if there is nobody in-front of you and a parade of bikes behind you, don't just whack the throttle down the straight. Allow the faster riders to pass if its safe for them to do so. They are faster because they can maintain higher cornering speeds, not because they have more engine mods to win the drag race.
8) Never pass the person in front of you in the same lane, except when at a stop sign, the group is stopped, or the rider in-front of you signals you it's ok to make the in lane pass.
9) Do not pass more than ONE space at a time, making sure there is sufficient space to merge back without running up on the rider in-front of you. If there isn't room to merge back into the group safely, don't pass. There is no reason for extreme straight line speeds.
10) Passing cars. The lead riders will most likely pass cars wherever there is an opportunity to do so. The rider in-front of you passing a car is not the signal for you to pass the car. Pass only when you are comfortable making the pass. Wait for the rider in-front to complete their pass before starting yours. Be patient.
Good post.
It's also a good idea to have a sweeper at the back of the line who knows the route incase there's some unforseen seperation in the group.
In larger group rides we always had one or two riders that helped with traffic control. When it was safe they would pull into the intersection to control traffic so the group could all get through stop signs together and then rejoin the pack at the end.
Hand signals are such an important communication tool for group rides.
Good post.
Good addition. I'm counting on semi to sweep like he has for all the other org event ride. :thumbsup:
Great Info for everybody, Im bring chatterbox X2 with 5 mile range, I have one for sweeper to use. We had WHITELE use one last year. worked great so the person in front knows whats going on behind them. Also a good tool for when the patrols are out.
Great information, thanks for your time writing up!
Posted via Mobile Device
Hand signal is tapping the top of your helemt to let everyone know. "Smokey ahead" (int.-bubblegum machine):thumbsup:
Yes works Much better when you have a group of 3 or 4 and the lead person is 1 to 2 miles head and the other 3 can slingshot at a spirited ride to catch up :laugh: Im just saying.....
i'll be there :beerchug:
i've got an Autocom Super Pro Automatic w/ a Motorola radio installed under the hump...it's supposedly good up to 35 miles but i think that only works if your transmitting from one mountaintop to the next :laugh:
Looks like Semi is gonna get a good view of my bike!! I always ride in the back of the pack. TOO MANY group rides turned bad for me to be in the front gettin' rear ended or taken out. Call me the slow-poke, but you can still call me, 'cause I'm still here...
:beerchug:
I have like 35 channels so im sure we can get one of the channels to comm to one another.
Semi, you my LEAD MAN LOL...
Gang, this may be of help, after leading professional tours for nearly 10 years, here's some of our safety brief.
1. Stay away from the White Fog Line: Right hand turns, stay to the outside. Do not cut corner if shoulder is same height as the road. Sand/Gravel in right lane.
2. Sport riding requires Delayed Late Apex technique: Choose your corner-entry-lane-position properly. Ride Outside-In.
3. Entry Speed is Everything: Entry speed determines corner outcome. Choose your entry speed appropriately. Brake leading up & into corner, 50% mark, release and power out.
4. 4th Rider Rule: If you find yourself trying to keep up with the 3 fast riders in front of you, you’re going too fast. The 4th rider is the guy that crashes, not the 1st.
5. No TRYING in Riding: If you are TRYING to keep up, it’s too fast for your ability.
6. Fast in the Corners, Slow in the Straights: Steady pace is best.
7. Lane Position most important on backroads: Can’t see around, take the high road. Do not ride along inside white fog line on blind right handers.
Decreasing Radius Corners
1. J-Hook Corner: Series of twisties, long straight appears and everyone speeds up. Do not do this. Steady speed & pace. At end of long straight is corner with a hook or corner that tightens up as it arcs around
2. Decreasing radius is: Smooth entry and arc, 50% mark, corner tightens up
good write up, i like staying in the very back so i can slow down and then hit the twisties a little harder, well at least for our military rides....most other group rides i do with my buds i'm always the lead man for some reason.
Great post. Too many time I've rode with groups that don't know WTF they are doing. So I just turn around and go on my own ride.
Sent from my iPhone using Tapatalk
