On my 08' I've been having some issues changing from 1st to 2nd gear usually whn I'm at the higher rev range.. but then again it will do it randomly at lower revs and speeds as well. .. this often results in grinding and such upon engagement. Has anyone else had this issue. I thought it might be my oil getting thin or something like that but I only have about 2k on this oil change. Was thinking of flushing the clutch fluid.. the bike has just over 6K on it. Will replacing the stock clutch line with a steel braided one help this issue at all? Thanks for any help.
