240 kit
eddiebusa74
:banghead: I would like to know what kind of sprockets you put on your hayabusa when you convert to a 240 kit. Help plz....
Other than the added weight of a bigger tire I don't see why a new rear sprocket is needed????
That is a very layered question
making a long story short
it will depend on the wheels you use
pm(performance machine) has a wheel that is older and has a 5 bolt pattern
their newer wheels and rc component wheels have a 6 bolt pattern.
Neither of these is compatible with a stock sprocket.
If im not mistaken the kit comes with the appropriate sprocket.
I build my own so i use various things to get the desired effect
and have used wheels with chopper hubs
of 3/4" and 1" axels
as well as sprockets that match those applications.
Hope that helps
