240KIT QUEST???
jboogey84
got a 240kit and a strut suspension for my BUSA so the bikes doesnt have ,,,so the bike doesnt have the coil spring and its a rc componets wheels with a metzeler tire but does any recommened a certain tire pressure??
i know the tire says 44psi but it seems to tight of a ride and yes i know i have a strut and yes i know i should fill it up as it tells me
You can run the wide tires alittle lower on the air pressure with hardtails to soften the ride up some. That's what the chopper dudes do.
Try starting it around the 32 psi mark. It should work good there. Just keep an eye on tire wear. And adjust the psi accoringly to get a good mix of ride and tire wear pattern...
+1
i to am running a 240 kit and the best thing to do lower your tire pressure to 33psi. should give you a softer ride
