3-hole lowering link, stock setting..HELP!!
FLY-N-PUMPKIN
I have a 3-hole lowering links on my bike. It is currently on the middle hole. How do you go back to stock when it makes the links hit the suspension piece? I just figured if they put that hole there you must be able to use it. I don't want to trim the links due to the furthest lowering hole might be effected. What do you do???
(FLY-N-PUMPKIN @ Sep. 12 2006,13:05) I have a 3-hole lowering links on my bike. It is currently on the middle hole. How do you go back to stock when it makes the links hit the suspension piece? I just figured if they put that hole there you must be able to use it. I don't want to trim the links due to the furthest lowering hole might be effected. What do you do???
dremmel.....
