Hello Everyone,
I don't post much anymore but, found some useful information I will share. My K8 is two years old, almost as soon as I purchased it, it suffered "warm starting problems". I believe these are actually heat soaked starter issues combined with a barely adequate factory battery.
Two years ago I upgraded to the Schnitz higher amperage battery,(235 Cold Cranking Amps Vs. 176 Cold Cranking Amps OEM). This battery worked great until last week, when the same "warm starting problems" showed up again. Is two years a very short battery life? I keep my bike garaged a ride almost every week, so I did not purchase a battery tender, perhaps I should have?
Anyway Schnitz now has a 380 CCA Battery! Almost sounds too good to be true. I purchased and installed over Thanksgiving. So far very very happy, the Busa has never turned over so quickly!
Link to Schnitz:
Battery, Suzuki Hayabusa * Schnitz Motorsports Inc
The description says for Gen 1, but works fine in my Gen 2.
The seat needs to be modified to accomedate this slightly taller battery, no big deal for my dremel tool. The battery has NO OEM markings, this started me investigating. Battery tabs also need to be straightened.
I believe the OEM, or originating distributor is Westco Battery, but I'm not sure which particular battery:
WestCo Battery - Motorcycle Batteries and Marine Batteries
I'm happy an even higher amperage battery is available with a minimun amount of modification.
1st pic is Battery Installation instructions
Link to Schnitz:
