49 State Fuel tank
cosmo
Has anyone actually attempted to mount a 49 state (5.5 gallon) tank to a California (5.0 gallon) frame and were you successful?
I probably should have elaborated a bit more so here goes. The problem is that the CA tank has a valve and tube that goes back to the evap canister and a check signal is sent to the ECU. Blocking the valve is a piece of cake but...fooling the ECU is a different story. Any ideas?
Got-R-Done
Yeah, I'd like to know too 'cause I brought my CA model out to NM last year. Did you have to do something with the throttle bodies? What year was your bike?
Etc, etc!!!
--Wag--
There are no wires, only emissions hoses. There is no way the canister can effect the ECU. I simply pulled the canister off and all the hoses.
So the long hose that goes from the canister to the throttle body (it is a two hose set, acutally) is removed at the throttle body? Do you have to plug the opening then? Or just let air go in there?
Also, I have been thinking about whether it is possible to simply use the non-cali tank with the canister. If one routes the tank water drain hose in a regular fashion and attaches the tank breather hose to the canister, would that work?
