60m.p.h. burnout !!??
hangman1300
my brother did this on his zx9r so i had to do it too.
at 60m.p.h. in 2nd gear apply front brake and full throttle. boy you can realy smoke the sh** out of the rear tire and lay rubber for miles.
another stupid cool trick
Or you can skip the front brake and just use a worn out OE Slipstone on the rear. I'm loving my new 207.
Hit the front brake and full throttle to start the burn, then off the front brake ? or stay on it through the burn to keep the weight shifted forward ?
Be carefull grabing that front brake!!! I've had two budies this year wash there bikes out by grabing the front brake. Just clutch it, rev it, and dump it. That should spin the tire at any speed.
