OB_Hooshy Bushy
I've got a '98 9R that has developed a clutch problem. I've got 11k miles on it and recently upgraded the springs. Soon after the clutch is slipping at 9k-up RPM.
As soon as it started to slip I replaced the frictions and scuffed the steels. Nothing was burnt just a couple glazed spots on the steels and they were within spec.
I put everything back together reusing the upgraded springs and it was then slipping more than before.
I took it back apart, replaced a couple of the steels with thicker ones and also got a new set of springs from a different company.
As of now, it is still slipping. I read a post from a ZX-12'er that is having something similar happening and they made a reference to "spider washers".
Anyone seen this before?
The clutch pak is so tight right now that I can barely get into neutral so I don't see how it could be the culpret.
This and other problems from my previous Kaw, led me to buying my '00 Busa! Thank you Kawasaki for making my decision this year easy!
