99-00 ecu
I have heard tale of guys using 99-2000 ecus on later model busas.Anybody else heard such a thing?
'99-'01 Busa's use a 16 bit ECU
'02-'07 Busa's use a 32 bit ECU
Gen2 '08-'09 are different
None of them are a straight swap...you will need the wire harness and will still have to do some mods to the wiring.
Found this on Dragbike.com,,converting the old to the new.
99-00 models - swap ECU pins 36 & 43, 56 & 33, and 60 & 53
Install 02-07 rotor
Install 02-07 ECU
'01 model
Install 02-07 rotor
Install 02-07 ECU
Using up 99-00 ecus on stock bikes that otherwise are paper weights. :thumbsup: Sell off the late model stuff that brings money. I already converted my streetbike to the 01 ecu and rotor,bike never knew the difference. :laugh:
Then why did you ask if it could be done if you already have???
