99 Busa
Pipe Dragger
Please help. 1999 Busa with Two Brothers Slip ons and K&N Air Filter. Can't find a Power Commander map for this set up. All maps found are for TB Slip ons but Stock Air Filter.
Best bet is what Johnny said. USE A STOCK MAP. Fine tune the map on the power commander buttons LOW--MID--HIGH depends on your ridding style.
Thanks Johnny Cheese and Ninja Eater for the response. One quick note, the Two Bros Slip on with stock air filter seems to work, but when I really get on it the FI light comes on. I thought she might be running too lean at the high RPMs because of the introduction of more air into the mix. I don't know enough to fine tune to compensate. I was hoping maybe someone else had the same set up and had the knowledge and might share their map with me. It would be greatly appreciated if either of you have the knowledge and might make a suggesstion to some tuning numbers?
Thanks again.
