lowandslow08
Last week was the first time trying out the lockup at the track and I had some issues with it. I bought it used and it came with a new billet outer basket, quick access cover, springs, and the lockup. I started out running the springs it came with and had nuts and bolts with two washers (on three arms only) leaving at 8000 rpm and it acted like it was was not slipping much at all then it would lock and bog or the front would pull up. I ended up pulling the washers off the arms but it still acted about the same. A few days later I tested all the springs that were in it and they four of them were 47 pounds and the other two were each 70 pounds(=328 pounds). Then I measured the stock springs and they were 47. 5 pounds each. Im assuming it should be set up with lighter than stock springs but what should be a good point to start with? Now the total spring weight is 258 pounds and a total of 29.1 grams of weight on the arms. Id like to set it up to dump the clutch off the line or at least close to that.
