What "next" busa?That's what I'm doing to my next busa. I like the look of the undertails, but the signals are almost invisible.
You can also cut the lower piece of the fender off and then use it as the template to get the "factory shape" in a shorter fender.
Kent
I plan on getting at least one more. Of course I'll keep my 04 forever. ( I look too damn good on it!)What "next" busa?That's what I'm doing to my next busa. I like the look of the undertails, but the signals are almost invisible.
Looks great , i did mine the same way ...Now take the plate bracket and move it up a bit and flip the bracket upside down .. Then it will cool very cool...Lee..I used a Dremel cutting wheel and a Bondo shaper. I wanted to keep the stock look without the giant mudflap. I'm very pleased with the result!
Nice work.I like the close to stock look too.I used a Dremel cutting wheel and a Bondo shaper. I wanted to keep the stock look without the giant mudflap. I'm very pleased with the result!
Damn, I,ve seen better heads on a Cabbage.
