Adjustable kickstand
I ended up getting a T. rex racing kickstand . Works great thank you all for the info
But I have a problem with both this and the Brock's. Where's the nub sticking out on the outside of the stand for you to find with your boot? I want the kickstand to be easy and unconscious muscle memory. I don't want to be trying to find the stand with my boot every time. Why would they omit this? Do you guys really not miss it? The T-Rex looks fine and is half the cost of the Brock's so maybe I'll buy it and just add a bolt...
Actually, I had another question. I'm going to buy one of these, and I'm going to cut myself a block of wood. The block of wood will go under the kickstand when it is engaged and the bike is vertically balanced with the handlebars straight and the front tire against a curb. Actually the bike will probably be leaned a little bit to the right. Then with this portable lift I'll jack the rear off the ground.
https://www.amazon.com/dp/B09GM17ST...colid=ZQ9TKRSFS4FO&psc=1&ref_=lv_ov_lig_dp_it
Then I should be able to comfortably spin the back tire to clean + lube the chain (if I'm touring). But this plan only works if the lighter weight aluminum aftermarket kickstand can support one-third the weight of the bike, ie 200 lb roughly. Any opinions?
Even this Sidestand must been Mod.
I have a Brock's stand and would not recommend. It's a more vertical stand meaning it doesn't have the angle as the stock or other aftermarket stands. It's a SOB to find below the QS, there's barely anything to grab my shoe to pull down. I can only imagine this will be worse with my boots on. Short of the header, I'm not impressed with Brock's stuff. While stuff does technically work, it is not ideal for the Gen3.
I don't have the feelers on my pegs, but it appears the T-Rex at least protrudes more from the QS for easier to use. Can you confirm?
Sorry, my white new bike is still in its crate. I'm trying to find a garage to put it in, and when I do I'll let you know. I think you still need to mod both these stands, which I did to my gen 1, but then again I was always very careful parking the bike. My biggest cringe is seeing people who park their bikes pointed down hill. Or who don't back the bike's rear tire up to the curb when one is available.
*Good illustration / diagram though. That's going to help a lot of people find the right part...
@pashnit
He uses this style lift for roadside repairs, tire plugs, chain lube.
I'm not sure which brand he uses, but it supports his gen2.
Was worth a shot to ask. I really dislike Brock's stand due to the angle of it as well as hard as crap to grab it with my foot..... and I've only used it a couple of times. I'm lowered, but had I realized this I wouldn't have purchased for sure. I honestly regret 3 of the 4 things I purchased from Brock's for this bike.
Nice! Anyone have the weight of the T-Rex stands and if they will extend longer than the stock or just shorter?
So they won't extend longer. I emailed T-Rex for the weight and was told 3lbs (double the factory stand). I called them and was told 1.5lbs... don't believe that either... :confused:
@Flows
What exactly do you want?
Are you looking for a longer kickstand to give the bike less lean to the side?
Or do you just want a kickstand that is lighter than stock?
I will need a longer kickstand with the raised front and rear end, swapping out with lighter is the win win.
@Flows
I am not sure if anything that T-Rex have said about their own product is correct.
Does anyone have one to hand that can verify the weight and max length.
