Adjusting the low beam?
quikbusa
Can someone refresh my memory on the low beam adjustment. I need to raise it up a bit. I know the high beam is the bottom right screw if you are sitting on the bike.
Thanks.
try this..if not I can email you the page..
hogger...
<!--EDIT|hogger
Reason for Edit: None given...|1154276192 -->
Thanks Hogger. Someone said there was no way to adjust the low beam, but there has to be. Thanks for the info.
