ham4864
i put every thing back together after adding the second fan.Now i'm burping the system.I have fill filled radiator,rock bike side to side,filled again,rocked again,filled again,till a can not put any more fluid in radiator. i start the bike and let run for 10 minutes.(Fans came on about half way mark).let bike cool off than rechecked and added more coolant.i then started and let run for 15 minutes.(fans came on as normal).i'm letting cool off.(now i have to go to work)I'll be back in 8hrs.
The question is how do you know when you have put enough coolant in the system.I i'm correct the manual says it take 3.1 gallons.So far it only took 1.5 gallons.Is there a way to know when the thermostat is open.
i'm i doing these steps right.any tips,pointers,or advise would be great.should i let the bike run longer,should i unplug the fan switch.lease:help.
