Hey guys. I recently swapped my 2000 to a 2nd gen gauge cluster. Aside from the check engine lights gear indicator and abs light that keeps coming on......my temp gauge keeps going all the way up...then the fi light comes on and it immediately drops to normal range...then the fi light goes out and it shoots up again then the light comes on again and it drops again ...this just keeps going over and over again.. Im not sure what is causing it but I need to accurately know my temperature. I must also note that the kick stand sensor as well as the tip over sensor have both been deleted and I've also put in a fen 2 radiator and oil cooler. The radiator has been bled as best as I can. I originally thought that was the issue until it did this immediately upon starting the bike.
I wanted to know if anyone had a solution to this or if someone could suggest an aftermarket gauge as well as let me know if the gauge is mechanical or not. Thanks alot
