Aftermarket fuel pump recommendations???
Bike382
Does anyone have any recommendations on a good aftermarket fuel pump for land speed racing.  Landspeed Larry uses an airtec w/ a mallory regulator.  Has anyone else used this setup??
I have a Power Commander, cams, airbox mod, head work, etc. and will be running NOS.
Any input would be greatly appreciated.
T-rex Fuel pump, located in the rear of the bike. cartec rising rate regulator, that you can set from 70-100lbs and a good fuel rail.
Where can I find these at?? How about the fuel rail, does it do anything for the HP? Any idea of the costs?
Thanks for the help
Fuel rail does not do anything on its own, but adds hp through pump regulator etc. You can find the T-rex on the internet also the regulator. The fuel rail you can get throughTDC Performance Or you can get them to put the whole package together for you. Most likely for the same or better price that you can get the stuff for. Others can get the sstuff for you also and many are very reliable. This is not meant to be a commercial for TDC so jsut let me know if you need more help are info.
