OB_KawAbuser
Frank, the Ohlins Busa spec shock has no accomodation for ride hieght. Contact Stigg Peterson at Peterson Pro Suspension, they are the west coast Ohlins service center. Stigg can construct a special shock for you for about $1250.
The Ohlins Busa spec shock lists for $1100
Penske makes custom shocks, they really do not make a production spec part as all their shocks are custom builds. $950 - $1150 depending on options(reservoirs and variable compression adjustments). They may ask you to send your stock shock to take dimensions from.
