I appreciate the opinion, this may sound like a dumb question but here go's. I dont quite get what the PCIII will do for me or even what it does I read on these boards that alot of people have them , so what do they do? Also where is a good place to get one and should I get PCII or PCIII and is it easy to install and (yes one more question)what is a good price for one........Thanks again
Sierra did a good job with the technical, so let me provide some basics. How you ever modded a carb. motorcycle? If so, what three things do you do with a stage one build?
1. high flow air filter (i.e., BMC, K&N, etc.)
2. high flow exhaust (i.e., Muzzy, Yosh, etc.)
3. CHANGE THE JETTING!!!
Number 3 is critical, why, because you need to get more fuel into that beast to compensate for the extra air (high flow filter) and extra exhaust flow.
Now, you are dealing with a fuel injected bike, the same thing applies, more air, more exhaust, means more fuel, otherwise you begin to lean the bike out, which is bad. It may run faster and more powerful, but you may be running lean. Some say "lean is mean", but those people enjoy changing pistons, valves, etc.
See what I mean? The PowerCommander can compensate for the higher air and exhaust flows by adding in more (or less) fuel when needed during any part of the RPM curve (it is way more complex than this, but this is the basic scenario).
