Air lock?
tattoo
I just did a oil/filter change on my bike.  It started fine when I checked for leaks, but after shutting down to replace plastics it gave me a "check" with the oil light on when I went to restart.  Double check everything but still wont turn over or even prime the injectors.  Any solutions?  Thanks
NEVER MIND....FIGURED IT OUT!!! It's that damn red switch on the right.
<!--EDIT|tattoo
Reason for Edit: None given...|1149731359 -->
The only times I've ever had that problem is if I don't have the clutch in all the way. Tells me you have a problem with a switch and I'm sure it's unrelated to the oil change. Pure coinkydink.
--Wag--
