Going to do a full exhaust system and was wondering what happens to the air pump and the tubes? Bought an 02' with 5555 miles and it came with bolt on Staintunes, gotta upgrade, already got the PCIII and got it dyno'd. 156hp 97#s. These things are fun to ride! Hooked!
Same thing that happens to that stock system. You lose a lot of weight. I hold on to my stuff just in case the annual vehicle emissions testing comes my way. Don't forget, back to the dyno for a tune with your full exhaust and PAIR block off plates.
You'll need 4, one for each exhaust port above where the header bolts on. Our sponsors sell them. There's also the Marble Mod (use Search above) which I believe does the same thing without removing the PAIR system.
Yea axe that pump and tubes, not alot of weight but adds alot of room up there, I cut the flanges off the tubes and plug welded the holes up..or you can buy the block offs,
