Mathewrussell52
I know the ecu can do some things what do I need to do and buy to get a air shift auto shift in my gen2 2 turbo.
and the upside from buying anything from frank is that he actually answers his phone and stands behind what he says.POWERHOUSE sells and installs Raptor shift lights. Different versions are available, and the auto shift version also uses a launch function. The light will light up when you reach a pre programmed launch rpm setting, and then once the bike is moving, the light will light up at pre programmed shift settings. It can also shift the bike automatically when it hits the shift point. Simple to set up - a few wires and you are done. We have one on Ali's bike . . .
a genius with a spring is better than a dunce with the best boost controller on earth... on a turbo bike that is used on the street.. less complexity is the way to go.... imho...Ya, it's expensive but there's a big difference between a $110 shift light and the RSR air shift module. The RSR has adjustable shift count, kill time, solenoid advance time, and shift point per gear. It's like comparing a spring to the NLR AMS 2000. They both control boost yes? Some people like nice things and aren't interested in a race to the bottom regarding price but as you said "to each their own".
Says the guy with a water/air intercooler, AMS 2000 and a Gen 2 multistage lockup clutch that pays a shop to fix his bikea genius with a spring is better than a dunce with the best boost controller on earth... on a turbo bike that is used on the street.. less complexity is the way to go.... imho...
The point is this bike had great high quality parts throughout... it still didn't stop someone from screwing it up... and on a big turbo bike... honestly.... I don't have a clue and I DONT WANT TO try to fix it myself.... its best left to a pro.... I don't want to screw it up... im not a motorcycle expert and Im not going to experiment with this one... and hack it all up.... thank god for experts.... and my guy ALWAYS answers my calls... old school guy.... he gets poop DONE.Says the guy with a water/air intercooler, AMS 2000 and a Gen 2 multistage lockup clutch that pays a shop to fix his bike
I try to keep it as simple as possible... under the circumstances and power levels involved... I don't have a clue what im looking at.... its working great now... and we know why its working great.Says the guy with a water/air intercooler, AMS 2000 and a Gen 2 multistage lockup clutch that pays a shop to fix his bike
How do you get the Raptor not to try and shift into 7th gear? I've been told by several LSR guys that the 7th gear shift thing is a problem..
You can use a switch to interrupt the signal to the relay or the output of the relay. Once you are in high gear open the switch. I repurposed my emergency light switch on my bikes to do this with my Boost by Smith and it could be done with the Raptor the same way.How do you get the Raptor not to try and shift into 7th gear? I've been told by several LSR guys that the 7th gear shift thing is a problem..
yupYou can use a switch to interrupt the signal to the relay or the output of the relay. Once you are in high gear open the switch. I repurposed my emergency light switch on my bikes to do this with my Boost by Smith and it could be done with the Raptor the same way.
