Multi-Function Hub
The Multi-Function Hub allows users to access advanced expansion features. Several optional harnesses are available to permit both input and output to/from the module.
Analog Output
Based on the data from the Power Commander and the inputs from the Multi-Function Hub, a solenoid, relay, warning light, etc. can be triggered. This can be used to activate items such as a shift light, Nitrous Oxide system, or air shifter.
