Couple questions.
1) I'm assuming air temp sensor gets pullled from air box, plugged in, and just hangs out of the way?
2) Does the atmospheric pressure sensor (also called baro sensor?) get plugged in but with all vacuum lines get removed? (The pic is hard to see but that is just the plug with sensor plugged in, the sensor is just sitting on the frame to the left of TB
3) Also, off of TB #1 there's a one-way check valve, I can just leave it in place or is there supposed to something that needs to see vacuum off of there?
(FMU vacuum is off TB #4)
