anytime you go to a full exhaust system it's a good idea to get a tune. You're not taking fulladvantage of the upgrade without a tune. Plus you may end up running a bit on the lean side.
Ok more expence then!dont want to buy a pc3 any idea on the cheapest route?will not be running it noisey[cops!] is ecu adjustable?I am told lamda plug is fitted surely this will help with fueling?as you can tell im no expert on tuning thanks for the advice!
check out some of the ecu editor threads from "smithabusa". It's probably one of the least expensive routes for tunning and it's also the most powerful route because of all the extra functionality built in.
