Alarm Help!
ThisFackinGuy
I have a 2017 hayabusa and I recently purchased a new Scorpio i900 alarm system. Having an issue with install!
I uploaded photos of the instructions and the final connector that I'm having difficulty finding a connection to.
I connected the red wire to positive and the white/blue wire to negative but I'm having trouble with the white wire w/quick connector and finding a 12 volt switched wire source and it can't be LED. anyone know the wire color for the license plate light?!
the blue connector unscrews to show a pin. I'm assuming the 12v switched power source i'm looking for goes in between the cap and pin is closed into it?
Thanks for all your help!
So I would unscrew that blue cap to expose the pin and sit that brown wire in between the pin and recap the connector? That's essentially what the instructions were saying.. Just didn't know the correct color wire.
Thanks for the diagram!
I could tap into the brown wire from any location? The brown wire in the photo I attached is in a tight spot. Does that feed to a harness by the battery?
