Okay, got another bike issue. Better yet - another starting issue! Different bike though, so not so bad. Alright, about a month ago as I was debating going to the Bash I got Baby J cranked up. Took a little bit, but she hadn't really been run in quite a while. Took her down the block and realized I needed to adjust the brakes, but no other problems.
Fast forward to now. Midnight is running great, so I decide to tackle the brakes on Baby J. Go out to start her up and she cranks, but won't turn over. I know what you're thinking - here we go again. Actually wish it were that simple. Maybe the battery is low, so I charge it up overnight and voltage reading is good (12.7V off, 12.5V on). Turn the bike on - dash lights work, gauge needles sweep, starter relay clicks, BUT NO FUEL PUMP! Check the kill switch and its on - retry and still no fuel pump. Check fuse - good, check fuel relay - good, check kickstand switch - good, check ECU - good, check connections - good, check turn signal/sidestand relay - good. Try between checks and nothing from the fuel pump and no codes.
Anything else I might try before assuming its the fuel pump gone bad? Is it the fuel pump? When the ignition is turned on and the gauges sweep the fuel indicator indicates a half a tank (which is correct as I put that much in it on Saturday) and when I disconnect the fuel pump it sits below empty.
As far as mods I have done nothing to the engine, but do have a PCIIIR and a GiPro. Disconnected both and no change.
Just want to make sure its the fuel pump before I get another and go through the process of removing and reinstalling. Thanks in advance.
