Hey Guys,
I have an unusual (electrical ?) problem I'm wondering if anyone else has experienced ? It's a 2000 Gen1 model. The bike runs a bit rough, although I've done all the valve clearances and synchronised the throttle bodies etc, except when I connect the dealer switch and turn it on (-00) no fault codes, the bike runs normally, very smooth idle and responsive. When I disconnect the switch, the RPM drops a round 300rpm, sort of like when you turn the headlights on on some bikes, the rpm drops and the bike runs a bit rough again... I've gone through all the wiring, but can't find fault... It has a Power Commander 3 installed, and thought it might be related to that, so I disconnected it, but that doesn't make any difference... every time I flick the dealer switch on (-00), the bike runs normally, and flick it off, idle drops a few hundred rpm, and runs slightly rough...
The charging at the battery is around 13.4V.DC at 5,000rpm, I know it should be minimum 13.8V, but not sure if that would do it... I've had other bikes with charging issues, but they don't drop rpm...
Any ideas would be greatly appreciated... Cheers Sass
