I went down the K&L route. The stems ended up leaking, causing me to have to pull the rims and rubber apart to remove them. Some people have been able to install them successfully with larger rubber gromet/gaskets; but I was not. I have since bought the subject stems in blue and I think they are going to work out very well!Notice, be very careful when ordering valve stems. The correct size is 11.3 mm for stock wheels. There are some non-Ariete stems around that I have seen that will not correctly fit the OEM wheels. The incorrect ones I have seen are 8.3 mm, only available in silver, and have a black plastic cap. I believe there are sources others that may fit, but confirm. The K&L Part number 32-5414 will not correctly fit an OEM wheel.
This link has pictures and more info.
https://www.hayabusa.org/forums/?act=ST;f=6;t=84238;hl=Ariete
I came out on the wrong end on a set and I sure don't want anyone else to do the same.
Yes KeithWhat are the steps for install? Dismount tires from wheels?
I'm calling vendor in the am to check but last known only black,silver and blue were available,but these are real ariete ones not knockoffs so other colors might not be available..
I may start a post for them once I find out..
