Bear with me, been a member here for a while but hardly ever post preferring to use the search as many issues I've had have been solved previously. I have to say this forum has been a godsend lately getting me to the point I am now.
I've a Gen 1 Hayabusa (2005) with less than 1000 miles on the clock that won't start. Has been in storage since 2012 and obviously not ridden much before then. Bike wouldn't start when put into storage.
Has new battery and a new fuel pump (old one was dead.) Tank cleaned before refitting. I have spark and fuel to injectors. Injectors are getting pulses from ECU. No errors in 'Dealer Mode'. Bike will splutter if cranked and carb cleaner sprayed into throttle bodies.
Have just pulled the injectors and the two on the centre two cylinders do not 'click'/activate when tested with a 9v battery.
Questions (apologies if considered stupid but I'll ask anyway):
1 I take it this is more than enough to prevent the bike starting at all?
2 I hope to get these cleaned/refurbed/serviced in the UK, if so any suggestions for who/where or is it a case for replacement?
Cheers
Cheers
