arthur39
seen 2 ways of doing this on the Hayabusa, some install check valve on the vacuum line into the FMU which would not allow the fmu to see vacuum. Corky Bell's website explains it this way:
"Two functions are accomplished by the check valve. One, the simple plugging of a small vacuum/boost leak. Second, vacuum is required to pull the pre-load spring under the center screw away from the valve so stock fuel pressures can be achieved under manifold vacuum conditions. The check valve white end attaches to 4" vacuumline, and the line plugs onto the 10-32 hose barb attached to the needle valve. This allows venting the boostsignal for adjustment, but will seal under vacuum. The check valve blows off into the atmosphere, do nothook it to the manifold or anywhere"
I am confused a on the right way of doing this on the bike, can someone clarify this? thanks
a pic is included to the way I think Corky Bell is suggesting
